Activity Forums Adobe After Effects Expressions Any way I can make this recursive expression elegant?
  • Any way I can make this recursive expression elegant?
    Posted by Darryl Torke on May 6, 2014 at 1:01 am
    Basically, I like the result of the ‘easeOut’ expression, but wanted it a little ‘sharper’. Unfortunately, the only way I could seem to get it some what desirable was repeat the expression over and over again so the the ease was stronger. I know there has GOT to be a better way, if anyone could point me in the right direction for my future expression I’d appreciate it.
    Thank you.
    G1 = transform.position+[0,100];
    G2 = transform.position;
    finalPoint = inPoint+[1];
    f = easeOut(time,inPoint,finalPoint,G1,G2);
    f;
    l = easeOut(time,inPoint,finalPoint,G1,f);
    l;
    j = easeOut(time,inPoint,finalPoint,G1,l);
    j;
    easeOut(time,inPoint,finalPoint,G1,j);
    Dan Ebberts
    replied 12 years, 4 months ago
    2 Members · 1 Reply
  • Dan Ebberts
    May 6, 2014 at 10:58 pm
    I don’t know that this is much better:
    easeOut(easeOut(easeOut(easeOut(time,inPoint,finalPoint,0,1),0,1),0,1),G1,G2)
    You probably could set it up as a recursive call, but I instead of doing that I would go to Penner’s quartic ease out formula.
    Dan
