Activity › Forums › Apple Final Cut Pro Legacy › Any tried to use FCP5.1 universal to work with a project created in fcp5 for powermacs ?
Posted by Todd George on May 17, 2006 at 2:39 pmHello all
have a unique situation
I have an intel Imac running os 10.4.6 I have fcstudio ver 5.1 I also have fcstudio for my powermac and G5 which is ver 5.0x
anyway created a project on the powermac version went to open it on the intel version and was told no
anyone else run into this issue and are there work arounds
thanks for any help
take care
by the way all my macs are running the same os and same software fcp5, dvdsp4, motion2, compressor2
Drizzt_g replied 20 years, 3 months ago 6 Members · 9 Replies -
David Bogie
May 17, 2006 at 4:21 pm“no” and what else?
Relevant.Are your two installs using the same license?
We do not have the Intel hardware but our 5.1 installs on our G5s open our older projects instatnly.
bogiesan
Michael Hoffman
May 17, 2006 at 4:39 pm5.1 is not backwardly compatable.
one workaround is to use XML export to transfer the project file back to 5.0.4
the simplest solution is upgrade everything to 5.1
cheers,
x -
David Bogie
May 17, 2006 at 6:06 pm> I have an intel Imac running os 10.4.6 I have fcstudio ver 5.1 I also have fcstudio for my powermac and G5 which is ver 5.0x anyway created a project on the powermac version went to open it on the intel version and was told no< The post is clear as mud, true, but I read it as the 5.1 is on Intel and v5.0 is on the G5. Projects created on the G5 in 5.0 are not opening on the Intel in 5.1 which is clearly a problem but it's not a backward compatible issue. But that's just how I read it. You read it differently. Probably neither of us is correct. bogiesan This is my standard sigfile so do not take it personally: “For crying out loud, read the freakin’ manual.”
Todd George
May 17, 2006 at 6:19 pmHello again all
my original question may not have had enough details so I will begin again
In my office I have 2 imacs
imac1 is a g5 powermac
imac 2 is a dualcore intl mac
both macs have seperate seats of final cut studio running on them
at home I have a G5 dektop and a G4 laptop each of them have a seat of Final cut studio running as well
I created a project at home on the g5 and brought the hard drive with all the material into the office connected that to the intel imac and tried to open the project I recieved a dialog box that stated the project could not be opened
it stands to reason that a few others out there might be in a situation where the own G4 or G5 macs running fcp5x on them and may also have access to the new mac running the universal install as well and perhaps they ran into the same situation
the replys I have seen thus far suggest that fcp5.1 is not backwards compatible with fcp5.0x
thanks again for any help or insight
Drizzt_g
May 17, 2006 at 7:05 pmFirst of all the PowerMacs are the Mac desktop computers running on G5 PowerPC processors.
From my experience FCP 5.1 will open a project from an earlier version except maybe if you used third party plugins not compatible with 5.1.
You definitly cannot open a 5.1 project in 5.0x.
If you open a 5.0x project in 5.1 it will convert it to a 5.1 project therefore you can’t open it back in 5.0x.
Suggestion install 5.1 at home.
David Bogie
May 17, 2006 at 7:51 pmNice try but you’re still not making any sense.
The machine has nothing to do with any file interchange situation. All that matters is the version of FCP.bogiesan
Dave Jenkins
May 17, 2006 at 8:36 pmAre you using any third party plug-in’s on you 5.0 machine?
Dajen Productions
Santa Barbara, CA
G5 Quad – AJA Kona LHe
Huge 1.2 Raid
FCP 5-OS X 10.4.2-QT 7 -
Walter Biscardi
May 17, 2006 at 10:05 pm[Todd George] “I have an intel Imac running os 10.4.6 I have fcstudio ver 5.1 I also have fcstudio for my powermac and G5 which is ver 5.0x”
Running FCP 5.1.1 here and opening FCP 5.0 projects just fine on two PowerMac G5 Dual 2.0’s and one Quad. It warns me that the project is an older version and it will update it to FCP 5.1.
Walter Biscardi, Jr.
https://www.biscardicreative.comDirector, “The Rough Cut”
https://www.theroughcutmovie.comNow Posting “Good Eats” in HD for the Food Network
Drizzt_g
May 25, 2006 at 7:03 amJust make a backup copy of your projet file if u wanna be extra safe.
