Activity › Forums › Adobe After Effects › Any suggestions…
Any suggestions…
Posted by Jmillz1 on August 22, 2006 at 4:32 amNew to AE – Any suggestions on the best way to accomplish the effect with the text.
https://www.cybmotion.com/projects/kasier_connections_qt.html
This
Steve Roberts replied 20 years, 1 month ago 5 Members · 4 Replies -
Vince Becquiot
August 22, 2006 at 4:54 amIsn’t that one of the presets coming with after effects ?
https://www.adobe.com/products/aftereffects/scale.html
Take a look at Zoom forward, just reverse it and I think you got your effect.
Vince
Eugene Perepletchikov
August 22, 2006 at 4:56 amJust have each letter on a seperate layer. Then turn all layers into 3D layers (check the 3D box next to each one). Create a camera, then initially place all the letters behind the camera in the z axis so they are not visible. Keyframe them to taste so they fly past the camera one by one just like in the example you provided, use ease in and out on your keyframes. Make sure that motion blur is checked for all your layers. Easy…
Good luck
David Modijefsky
August 22, 2006 at 6:13 amIt also looks that they’ve applied just a slight bevel edge to the letters.
Steve Roberts
August 22, 2006 at 10:28 am… and copy that text layer, reducing its opacity to get the echo-like effect.
