Activity Forums DaVinci Resolve Any opinions or suggestions on this workstation i’m thinking of…
  • Any opinions or suggestions on this workstation i’m thinking of…
    Posted by Javier Martos valladares on February 21, 2013 at 10:38 pm
    Workstation. HP Z620. WM439EA
    Description Z620/ RMT/ Intel Xeon E5-2620/ 16GB/ 1000GB SATA 7200/ DVDRW/ Win7Pro 64
    Form Fact RMT
    Processor 2 Xeon E5-2620
    Processor Specs 2 Intel Xeon E5-2620 (2.00 GHz, 15 MB cache, 6 cores)
    GHz 2.00GHz
    Chipset Intel C602
    GB 16GB
    Memory Specs 16 GB 1600 MHz DDR3 ECC Unbuffered RAM
    Max Mem 48GB
    HDD 1TB
    Hard Drive Specs 1 TB 7200 rpm SATA NCQ
    Type SATA
    Then 2 GPU: quadro 600 for gui and nvidia gtx 580 for processing.
    For monitoring: GUI any suggestion (2560×1440 is the preferred screen resolution)
    Reference: I have an Hp 2480 zx dreamcolor as a grading monitor so i will have to ad a BM sdi output card width 4:4:4 output ( don’t know wich one) and hdlink for sdi-displayport conversion for the dreamcolor.
    Sorry for my poor english.
    Javier Martos.Colorist
    http://www.24fps.es
    Javier Martos valladares replied 12 years ago 3 Members · 3 Replies
  • Juan Salvo
    February 22, 2013 at 3:15 am
    Go by the config guide, blah, blah, all that jazz. From the specs sounds ok. For whatever that’s worth. Nothing about the config sounds off. Keep in mind it won’t be the fastest system on earth, but would certainly be capable for HD/2kish type stuff.
    Colorist | Online Editor | Post Super | VFX Artist | BD Author
    https://JuanSalvo.com
  • Nurali Kushkov
    August 2, 2014 at 6:21 pm
    Javier how did it work out with HP monitor?
    Im considering similar setup but with eizo CS230 + aja hi5 plus.
  • Javier Martos valladares
    August 25, 2014 at 9:27 pm
    Don’t know about that Eizo monitor image quality but Eizo monitors have much better calibrations capabilities than the hp dreamcolor, also Aja lut box is a good relatively cheap one, much better than the HDdlink from BM.
    http://www.javiermartoscolorist.com
