Activity › Forums › VEGAS Pro › Any news on the old MB Looks and Vegas 64 bit discussion?
  • Any news on the old MB Looks and Vegas 64 bit discussion?
    Posted by Frank Manno on January 16, 2011 at 9:03 am
    Will Magic Bullet work with Vegas 64 bit?
    If not are there any known workarounds?
    -Frank
    Frank Manno replied 15 years, 8 months ago 3 Members · 3 Replies
  • Rob Franks
    January 16, 2011 at 2:41 pm
    Nothing as of yet. I know that they have gone 64bit for Adobe but Vegas is still stick at version 7, 8 (32bit). I doubt that they will issue an update for the old MBLooks anyway. They usually don’t. When a plugin comes with a particular version of vegas (or any other program for that matter), it usually comes with the understanding that YOU are responsible for any upgrading/updating that needs to be done.
    IF they come forth with a 64 bit version for Vegas…. I’m pretty sure you will have to pay for it.
  • John Rofrano
    January 16, 2011 at 2:48 pm
    [Frank Manno] “Will Magic Bullet work with Vegas 64 bit? “
    Magic Bullet has stated that they are not planning on a 64-bit version of Magic Bullet for Vegas Pro because there is not enough demand.
    [Frank Manno] “If not are there any known workarounds?”
    You could use Vegas Pro 32-bit to add your film look at the very end and then render.
    You could also buy VASST ReelPaks. They have the same looks, work in 64-bit Vegas, are less expensive, and render faster as well. All of the looks use Vegas internal plug-ins so you can tweak the look however you want.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Frank Manno
    January 17, 2011 at 1:11 am
    I like it – Thanks 🙂
    >>You could also buy VASST ReelPaks. They have the same looks, work >>in 64-bit Vegas, are less expensive, and render faster as well. >>All of the looks use Vegas internal plug-ins so you can tweak the >>look however you want.
