Activity › Forums › Blackmagic Design › any news on my 7.6.4 driver problem for PPro CS5?
Posted by Wolf on June 24, 2010 at 6:07 pmHi,
are there any news on my problem with decklink 7.6.4 and PPro CS5
https://forums.creativecow.net/readpost/124/874011Thanks
Andreas Quandt replied 16 years, 2 months ago 3 Members · 4 Replies -
Slobodan Milivojevic
June 27, 2010 at 1:59 pmGuys from Blackmagic are probably too busy to answer because they are fixing their drivers day and night …I have a lot of problems, too – everyday, both on PC and MAC…….
Wolf
June 28, 2010 at 7:56 amHi,
until i changed to cs5 i still worked with cs2 and deckling 6.4 driver
because this combination i stabel.
i tried cs3 and cs4 with deckling driver and had alway problems.
So now with CS5. one problem more with cs5: i remarked that the clips captured in mjpeg are more less in quality than the clip i captured in cs2 and 6.4 driver. when i have a clip b.e. with on coloure b.e. blue sky, the compression is not really good.
I bought a Mojo SDI on ebay and i´m testing MC 5.0.
It´s stable but it´s a big change, you have to make much clicks to have the same result!! 🙂
(But i need something stable with a good quality….for the moment it´s not possible with CS5 and 7.4.1 Decklink!!!)My life is great, but my edit-System sucks 😉
Greatings from Cologne 🙂
Andreas Quandt
June 29, 2010 at 2:19 pmSame problem here. No moitoring from Premiere or After Effects CS5 via Decklink HD Extreme 3D (Vers. 7.6.4). What we see is only a black screen with some flashes of stills of the monitored footage from time to time.
Final Cut Pro monitoring is doing well on the same station.Hope that BMD fixes this problem fast. Otherwhise we have to switch to AJA.
…best regards…
Andreas
