Activity › Forums › Apple Final Cut Pro Legacy › Any ideas to send DNxHD out HD-SDI
  • Any ideas to send DNxHD out HD-SDI
    Posted by Timothy Habrock on June 18, 2009 at 8:19 pm
    We are a QC house, but not an edit house, although we do have a FCP system installed on Mac’s with a AJA Kona 3 card.
    One of our clients wishes us to do a comparison between these HD Codecs:
    1. DVCROHD 100
    2. ProRes 422 145Mbps
    3. DNxHD 121 Mbps
    4. DNxHD 36Mbps
    We can play all out of the Kona SDI ourput except the DNxHD, all we get is a single frame. I know this is a well documented issue, but I was wondering if anyone is aware of any “cost effective” alternatives or solutions to output the DNxHD via SDI that does not involve any conversion.
    Thanks.
    John Pale replied 17 years, 3 months ago 4 Members · 4 Replies
  • Timothy Habrock
    June 18, 2009 at 8:15 pm
    That is what my research is seeming to indicate… I was hoping there was some other option…
  • Shane Ross
    June 18, 2009 at 8:23 pm
    Well, getting an Avid with MOJO DX really is the only option for this codec. It is an Avid codec. Proprietary.
    You have to have an Avid with HD Broadcast monitor next to FCP with similar monitor and to play the footage at the same time. I you don’t have that, there is no way to compare really.
    Shane
  • Walter Biscardi
    June 18, 2009 at 8:35 pm
    [Timothy Habrock] “That is what my research is seeming to indicate… I was hoping there was some other option…”
    Nope. We have done some tests here with the Avid DNxHD codec and Apple Color and this is what we found too. Playback is fine in the Canvas but no playback to the external monitor.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • John Pale
    June 18, 2009 at 11:19 pm
    Avid used to charge several thousand dollars for the card that allowed the Avid Adrenaline to play out DNxHD. Its a bit cheaper now with a Mojo. And remember, Avids themselves do not play out the Quicktime DNxHD codec…Avids use their own flavor of MXF media. The Quicktime codec is only for interchange with other programs. Avid is not a Quicktime based editing system.
