Activity › Forums › Panasonic Cameras › Any Ideas on Archiveing Footage from P2 cards???
Posted by Bobby Holbrook ii on June 6, 2007 at 3:23 pmHello Everyone,
I’m trying to find the best solution for archiveing all of the footage off of the P2 cards after the job is done. Will I need to use ext. Hard Drives for each client, dump onto tape or invest in a hugh raid system???? I really have no idea what the easiest, most practical way of approaching this. I couldn’t attend NAB this year so I really feel “out of the loop”. Any Ideas would help.
BobbyJoe Murray replied 19 years, 3 months ago 6 Members · 6 Replies -
D. scott Dobbie
June 6, 2007 at 3:30 pmBest for me are the new Quad Interface 500GB LaCie drives (2 Firewire 800 connectors as well as a FW 400, a USB 2.0 and the new eSATA). They only cost around $250 through MacConnection.com. I just creat a folder with the client name and load the cards into it. When one drive is full I store it and put a new drive in its place. I have multiple clients on each drive so it’s very cost effective. The drives stack nicely and don’t take up much room.
-Scott
Russell Lasson
June 6, 2007 at 3:43 pmWhatever you do, make sure you have two copies. We’ll be setting up a DLT-S4 autoloader (about $110 for a $800 tape) and also putting the finished project on a harddrive for easy access. We’ll keep the DLT tapes offsite just incase.
Or you could just use two harddrives. There are a couple of devices where you can just buy harddrives and trays instead of the whole enclosure. I don’t recall the name right now, but if I remember, I’ll get back to you.
-Russ
Steve West
June 6, 2007 at 4:04 pmI copy the P2 cards to a P2 store in the field- and if I have time and a place to work, I also copy the cards to an external hard drive hooked to my HP8000- which has a slot to insert the P2 cards- I use P2 Genie and copy to a seagate External drive. When I get back to my suite I copy the P2 folders from the P2 Store to a Dual Layer DVD. I then import the files to my Avid. Because I’m paranoid- I don’t reformat the P2 store until I need the space for another shoot. I figure it takes about twice as long to import and backup the P2 files than it does to digitize a tape and put it on the shelf when you’re done.
Time- Copy 8 gig card to P2 Store 8 minutes
copy to hard drive 12 minutes
copy and verify DL DVD 22 Minutes
Import to Avid 8 minutes
Total 50 MinutesDigitize 30 minutes of DV tape and put on a shelf- 31 minutes
Shane Ross
June 6, 2007 at 6:07 pmI archive to inexpensive internal SATA drives. 250GB bare drives. They cost about $80 and I have a $20 SATA to USB connector that I bought from OWC. Two of them archive all the footage from one shoot (100+ 4GB cards). Now, the network I deal with wants this footage as well, so I end up sending them a triple interface OWC drive, which is more expensive…but one that they can plug in a variety of ways.
As for future proofing…when new drive technology comes down the system I’ll transfer to those new drives. Just like we transfer our 3/4″ masters to digibeta. But that hasn’t happened yet.
Shane
Littlefrog Post
http://www.lfhd.net -
Joe Murray
June 12, 2007 at 1:37 amI have the AJ-HD1400 deck so I archive my P2 to DVCProHD tape. I also archive project files and consolidated media files to hard drive. Eventually I might consider an SDLT unit.
Joe Murray
http://www.editatjoes.com
