Activity Forums Adobe After Effects any idea on how i’d achieve this pattern/texture?
  • any idea on how i’d achieve this pattern/texture?
    Posted by Luke Trevitt on April 12, 2011 at 6:39 am
    Any idea on how i’d achieve this pattern/texture?
    REFERENCE:
    https://vimeo.com/7735980
    from about 1:55″ – 2:00″
    I know i’d start by building a vector triangle grid.. further that im kind of stumped..I like the way the triangles interact and realistically illuminate.. any pointers would be much appreciated! thanks in advance!
    Luke
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Luke Trevitt replied 15 years, 4 months ago 4 Members · 8 Replies
  • 8 Replies
  • Tudor “ted” jelescu
    April 12, 2011 at 8:40 am
    The player does not display the time and there’s a lot of triangles in this clip- can you be more specific? Is it the “diamond” like effect or something else?
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Luke Trevitt
    April 12, 2011 at 9:43 am
    Hey! thanks so much for the reply.. i didn’t realize the video would embed itself.. :o/
    its kind of a triangle kaleidoscope section.. if you right click on the video and “watch on vimeo” then use the timecode 1:55 to 2:00.. sorry to be a pain.. my triangle related vocab is a little limited…
    Thanks again for the quick response!
    Luke
  • Eddy Rose
    April 12, 2011 at 2:46 pm
    To me that looks like some 3D work, which is what BUCK usually does. I’d say we’re looking through a rotating geodesic dome with some heavy refraction pink and green image. I could be totally off, that’s just my best guess.
    How to do this in AE…tricky tricky…
    Obviously you’d have to fake it. I’d say start by making a triangle pattern, then use it as a mask for different colored objects at different positions and scales. Move everything around. Then add starglow. Lots of starglow.
    April 12, 2011 at 3:01 pm
    With what you have right now in AE it will be hard- Eddy had some good ideas. I would ad distortion maps- match the top layer of triangles creating a black and white image of the same triangles and use that as a distortion map on another layer with colored triangles. On top you would have the initial triangles layer composited with Add or Screen mode.
    With the new FreeForm Pro plugin from mettle you may be able to displace a triangle image in 3d, and then add a reflection map with another triangle image to create the look you’re after.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Cassius Marques
    April 13, 2011 at 2:20 pm
    That’s a 3D app and composition, don’t even try to do that within AE.
    Build a triagle grid, push some vertices backwards…put some reflective texture…and reflect something… If you don’t know how to do this – but you have the chance – it would still be a lot faster to learn than to get close to that in AE.
  • Luke Trevitt
    April 13, 2011 at 11:14 pm
    Thanks so much for the advice Tudor!
    i think i’ll give C4D a go on this one..
    cheers!
  • Luke Trevitt
    April 13, 2011 at 11:15 pm
    Thanks for you feed back! i think im going to try my luck in C4D.. Cheers!
  • Luke Trevitt
    April 13, 2011 at 11:17 pm
    Thanks for the advice Cassius,
    I’m going to give it a shot in C4D..
    Cheers!
