Activity › Forums › Maxon Cinema 4D › Any good camera shake plugin / script?
Posted by Marco on June 14, 2006 at 4:54 pmI’m looking for a good free resource about that … anyone?
Marco replied 20 years, 3 months ago 4 Members · 5 Replies -
Mylenium
June 14, 2006 at 7:39 pmUse the Vibrate expression tag. For more control, connect the Noise node in XPresso to whatever property you wnat to affect. Just use some Range converters inbetween or your results will not look correct. Because Noise only generates values within a certain range you need to make those conform e.g. to angular measurements if you need them.
Mylenium
[Pour Myl
Lennart Wåhlin
June 14, 2006 at 10:58 pm -
Adam Trachtenberg
June 15, 2006 at 12:07 amWhile you’re at Lennart’s site definitely check out SteadyCam Pro; it’s a sweet plugin for controlling camera animation–highly recommended.
