Activity Forums VEGAS Pro Any easy step a step b step c for using Digital Juice with Vegas?
  • Any easy step a step b step c for using Digital Juice with Vegas?
    Posted by Rick Rintala on January 5, 2008 at 5:59 pm
    Just purchased Digital Juice tool kits. Am trying to see if there is a easy step by step procedure to follow to incorporate Digital Juice files into my projects. I tried to just drop one of the lower third templates into a project but the upper two thirds are not transparent. Im a rookie , so please go easy on me. Are there any specifc settings in Vegas I need to be aware of? Or is the trick, learning how to use the Digital Juice Juicer to manipulate the files before I import them into my project?
    Allen Zagel replied 18 years, 8 months ago 3 Members · 2 Replies
  • Terry Esslinger
    January 5, 2008 at 9:26 pm
    Actually if you right click the file you dropped on the time line and choose properties and set the alpha channel to premultiplied or premultiplied (dirty) you should be fine. For some reason Vegas brings events in with the alp[ha channel turned off.
  • Allen Zagel
    January 6, 2008 at 3:11 pm
    Hi
    Also if you look around DJ’s site, there are step-by-step tutorials for using DJ products in Vegas. Both Printed and I believe a video that you can download. Check out their DJTV area and search for Vegas.
    Actually as Terry says above, once you learn the basics of setting the Alpha Channel in Vegas (Vegas works differently that other editing programs) you’ll find all the DJ products work about the same and are fun to use.
    There’s also a Vegas Forum at DJ for Vegas users.
    https://www.digitaljuice.com/support/knowledgebase/topic_detail.asp?tid=13
    This page has your answer. Just make sure you copy the entire link.
    Allen
