Any Clean Way of Adjusting White Balance in Post-Production?
I’m shooting a project right now that has required me to shoot with a simple camcorder that has the unfortunate curse of an automatic white balance setting. I try to use a large sheet of white paper in front of the camera before a shot to sync the white balance, but it doesn’t always work which is a genuine bummer since I’m colorblind and cannot always tell if the shot did not adjust properly.
I can tell the differences in color and hue later when looking back at the footage a lot easier, but it’s painful when I see the shots that did not white balance properly look orange-like. The cuts are quite distracting between white-balanced shots and non-white-balanced shots.
My question for the wise ones out there is this…
Is there a basic effect in Final Cut Pro that can white balance the shot a bit for me? Or at least make it a little less orange without sacrificing good traits of the footage?
Any help would be GREATLY appreciated. Thank you! 🙂
