Activity › Forums › Adobe After Effects › Any advantage to going from no compression……
  • Any advantage to going from no compression……
    Posted by Craig L. on May 5, 2005 at 3:15 pm
    If I am going to be exporting my project to MPEG2 for a DVD is there any advantage to exporting it from AE with no compression and then using that file to create the MPEG2 rather than exporting it as Microsoft DV which I have been doing to save disk space?
    thx!
    Judge S.
    Josh Michnik replied 21 years, 5 months ago 3 Members · 2 Replies
  • Steve Roberts
    May 5, 2005 at 4:23 pm
    Out of AE, either render to Quicktime Animation codec or Photo-JPEG. PJPEG at 89-94% quality gives smaller file sizes with negligible loss in quality.
    DV is very lossy. Not good as an intermediate codec.
    If you neeeed an AVI, then I suppose you need to use no compression. I’m not aware of any useful intermediate codecs for AVI.
    Steve
  • Josh Michnik
    May 5, 2005 at 4:28 pm
    You also could try huffyuv…pretty small file size and lossless
    but i recomend working in no compression
    especially if the client might want to output to broadcast
