Activity Forums Apple Final Cut Pro Legacy ANSWER TO!! – “Failed: Quicktime Error: 0”
  • ANSWER TO!! – “Failed: Quicktime Error: 0”
    Posted by Tom Laughlin on April 16, 2010 at 9:55 pm
    After hours of post reading this “QuickTime Error 0”, I found the solution by going through the time-line very carefully and coping and pasting portions of my project into another time-line and exporting out as ref QT’s till the error popped up, and I honed in on and isolated the clip that QT didn’t like to render, replaced it with dragging the same shot in, and re-rendering and BAM! 100% rendered and exported. If you have the time, it’s worth the fix, but if not, not sure what other options there are. The only other solution I found before was to output to an SD QT, rather than keep it at same settings or exporting to an 8-bit. All exports failed except for the SD 720×486(16×9)QT export using QT, not QT conversion. Then I tried this isolating the corrupted clip idea, and it worked. It was one little tiny 4 second cutaway shot in my 12 minute clip.
    I found these 2 posts to help me in that direction:
    https://discussions.apple.com/thread.jspa?threadID=1128297&tstart=0
    https://dvcreators.net/discuss/showthread.php?t=19191
    Tom Laughlin
    Producer/Editor
    Salt Lake City, UT
    FCS3/Sony EX-3/Mac Intel
    John Fishback
    replied 16 years, 4 months ago
    2 Members · 1 Reply
  • John Fishback
    April 17, 2010 at 6:44 pm
    Checkout FCS Maintenance Pack. It include a Corrupt Clip Finder.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
