Activity Forums VEGAS Pro Another Vegas 9.0b bug
  • Another Vegas 9.0b bug
    Posted by Sebastien Gravel on September 15, 2009 at 1:29 am
    Well, not sure if it’s been reported before. Using the trimmer and setting the In and Out points, I then send it to my timeline using the “a” shortcut. Several times now, the segment that is sent to the timeline is either just a short segment of my selection or altogether outside my in and out points Anybody else has had that?
    Sebastien Gravel replied 16 years, 12 months ago 1 Member · 1 Reply
  • Sebastien Gravel
    September 15, 2009 at 2:07 am
    Well, I think I’ve been able to replicate the bug. If the marker of the playback is between my in and out point, the clip sent to the timeline will actually be only taken from that marker to the out point instead of the in to out point. If the playback marker is outside the in and out points, the clip is sent entirely to the timeline as it should.
