Activity Forums VEGAS Pro Another Vegas 8.0 Pro error during render
  • Another Vegas 8.0 Pro error during render
    Posted by Joel Sacramoni on March 25, 2011 at 6:30 pm
    Hello guys,
    I was working for quite a while on a big project (length 11:00).
    Everything went smoothly untill I decided to render project which is quite big (224 GB), uncompressed AVI files.
    What I did was what I always do, render with settings on WMV, quality VBR, 50 fps and bitrate on 5000.
    Everything went smoothly and well untill my SV crashed, unfortunately.
    I was hoping if any of you might be able to help me out.
    Errorcode:
    Sony Vegas Pro 8.0
    Version 8.0a (Build 179)
    Exception 0xC0000005 (access violation) READ:0x0 IP:0x0
    In Module ‘vegas80.exe’ at Address 0x0 + 0x0
    Thread: ProgMan ID=0x1C40 Stack=0x38BF000-0x38C0000
    Registers:
    EAX=1f6385e0 CS=001b EIP=00000000 EFLGS=00010202
    EBX=00000000 SS=0023 ESP=038bf3f4 EBP=038bf448
    ECX=3d2c0f29 DS=0023 ESI=006bc2b3 FS=003b
    EDX=00000000 ES=0023 EDI=1fd81658 GS=0000
    Bytes at CS:EIP:
    00000000: .. .. .. .. .. .. .. .. ……..
    00000008: .. .. .. .. .. .. .. .. ……..
    Stack Dump:
    038BF3F4: 006BC2D8 00400000 + 2BC2D8 (vegas80.exe)
    038BF3F8: 1F6385E0 1E5E0000 + 10585E0
    038BF3FC: CADB0026
    038BF400: 8004E00A
    038BF404: 1F6385E0 1E5E0000 + 10585E0
    038BF408: 00000000
    038BF40C: 1FD81658 1E5E0000 + 17A1658
    038BF410: 80004005
    038BF414: 00000000
    038BF418: 00000000
    038BF41C: 00000000
    038BF420: 1F6385E0 1E5E0000 + 10585E0
    038BF424: FFFFFFFF
    038BF428: 00000000
    038BF42C: 80004005
    038BF430: 038BF3FC 037C0000 + FF3FC
    > 038BF43C: 0083C082 00400000 + 43C082 (vegas80.exe)
    038BF440: C9F620D6
    038BF444: FFFFFFFE
    038BF448: 1FD81658 1E5E0000 + 17A1658
    > 038BF44C: 006B196B 00400000 + 2B196B (vegas80.exe)
    038BF450: 038BF4B4 037C0000 + FF4B4
    038BF454: 038BF46C 037C0000 + FF46C
    038BF458: 00000005
    038BF45C: 1FDAE674 1E5E0000 + 17CE674
    > 038BF484: 004EECFF 00400000 + EECFF (vegas80.exe)
    038BF488: 00002FB9
    038BF48C: 00000000
    038BF490: 00001069
    038BF494: 00000000
    > 038BF4E8: 151B857A 15110000 + A857A (WMVCore.DLL)
    > 038BF508: 3A1074DF 3A0F0000 + 174DF (wmfplug3.dll)
    > 038BF544: 33564D57 33560000 + 4D57 (ac3plug.dll)
    > 038BF588: 00A00000 00400000 + 600000 (vegas80.exe)
    038BF58C: 00004E20
    > 038BF590: 01400000 01150000 + 2B0000 (vegas80k.dll)
    038BFFF0: 00000000
    038BFFF4: 00525180 00400000 + 125180 (vegas80.exe)
    038BFFF8: 00AD8658 00400000 + 6D8658 (vegas80.exe)
    038BFFFC: 00000000
    Thanks in advance!
    Joel
    Joel Sacramoni replied 15 years, 5 months ago 3 Members · 12 Replies
  • 12 Replies
  • Mike Kujbida
    March 25, 2011 at 7:13 pm
    #1. Only the folks at Sony can read and interpret the error code.
    #2. Why uncompressed AVI?
    #3. Why WMV?
    #4. Upgrade to 8.0c (lots of bug fixes) and see if that helps.
    https://www.sonycreativesoftware.com/download/updates/vegasfamily
  • Danny Hays
    March 25, 2011 at 7:20 pm
    Is your source video 50 fps? If not Try one of the .wmv presets that match your file res and framerate.
  • Joel Sacramoni
    March 25, 2011 at 7:30 pm
    Yes, files are recorded with FRAPS on 50 fps, resolution recorded was 1280-1024 but cropped to 1280-720.
    All fraps-recorded files are uncompressed avi.
    I have done this before, but with smaller projects (6:30 min).
    Will try to upgrade as you said, I’l get back to you guys later.
  • Joel Sacramoni
    March 26, 2011 at 12:04 am
    Ok, apparantly I allready had the Vegas 8.0c version.
    In the meanwhile I gave it another shot and re-rendered untill Vegas crashed again, this time not on 15% but on 22%.
    Is there any way I clarify my problem to give you guys a better idea?
  • Joel Sacramoni
    March 26, 2011 at 12:10 am
    EDIT: (sorry for the inconvenience)
    I just gave it another shot and re-rendered untill Vegas crashed again, this time not on 15% but on 22%.
  • Mike Kujbida
    March 26, 2011 at 3:37 am
    “Ok, apparantly I allready had the Vegas 8.0c version.”
    You say that but your error code says
    Sony Vegas Pro 8.0
    I have Pro 8.0c and my build is 260.
    Try rendering your Fraps footage to something other than uncompressed AVI (regular DV-AVI?) as that’s a real bear to work with.
  • Joel Sacramoni
    March 26, 2011 at 4:46 am
    I upgraded now to SV8c (was confused earlier)
    Fraps is a real-time video capture utility that is designed to record footage in games, it basically supports any game with (OPENGL and DirectX applications). Basically by just pressing your hotkey it records your AVI file (its not possible to record in a diffirent filetype.
    It is indeed very correct that uncompressed AVI files are incredibly huge before they are rendered. For example my project is 254 GB, and I expect it to be around 1 GB after rendering it in WMV. (my previous project was around 120 gb and the final size after rendering was 750 MB.)
    I heard from a friend that the folowing changes might help:
    Options -> Preferences -> Video -> Dynamic RAM Preview on “0”
    Options -> Preferences -> Video -> Maximum number of rendering threads on “1”
    I just gave it another shot by upgrading as you said and doing what my friend advised me to do.
    Thanks alot for helping me so far, let’s hope this works out well.
    (My excuses when there might be some grammar mistakes, my main-language is not English)
  • Joel Sacramoni
    March 26, 2011 at 6:29 pm
    Unfortunately no luck, any ideas?
  • Mike Kujbida
    March 26, 2011 at 11:37 pm
    Have you tried my suggestion of rendering it to DV-AVI first?
    If that works, then do a render to WMV.
  • Joel Sacramoni
    March 27, 2011 at 2:30 am
    Yes I will defenitely try that aswell.
    Uncompressed or with compression? (Lagarith codec)
