Activity Forums Apple Final Cut Pro Legacy Another Print to Tape Problem
  • Another Print to Tape Problem
    Posted by Rick Albertson on March 20, 2008 at 9:18 pm
    Print Timeline or Print to Tape – No image/sound
    I’m trying to print to tape or just tape the timeline of an HDV project using the system below. Don’t seem to have a Firewire connection when doing so, though capture over Firewire works fine. After recording to tape it contains nothing and HDMI monitor remains blank/no audio throughout recording.
    Tried to remove FCP prefs. – no change. Can’t locate QT Receipts mentioned in Apple’s doc: Restoring a DV device connection in QuickTime 7. Have mixdowned the audio. Full render.
    Would very much appreciate suggestions. Thanks. Already past deadline!
    Rick
    MacPro
    2 x 2.8 Quad Core
    4 GB RAM
    Black Magic Intensity Card (HDMI) w/latest driver
    Final Cut Studio 2
    QuickTime 7.4.1
    Sony HVR-M15U Deck
    Sergio Ornelas replied 16 years, 4 months ago 2 Members · 1 Reply
  • Sergio Ornelas
    May 6, 2010 at 8:35 pm
    Rick
    This is what works for me, hope it helps.
    Choose easy setup
    HD and select HDV
    Audio/Video Settings
    Summary Tab settings are as follows:
    Sequence Preset HDV-1080i60
    Capture Preset-HDV
    Device Control Preset-HDV FireWire Basic
    Video Playback- Digital Cinema Desktop Preview Main
    Audio Playback-Default
    Sequence Presets Tab settings are as follows:
    HDV=1080i60
    Capture Presets Tab settings are as follows:
    HDV
    Device Control Presets Tab settings are as follows:
    HDV FireWire Basic
    A/V Devices Tab settings are as follows:
    Under Video: Digital Cinema Desktop Preview Main
    Check Mark on: Mirror on Desktop
    Under Audio: Defualt
    Different Output for edit to Tape is-HDV (1440×1080) 60i
    Mirror on desktop is checked
    Audio is HDV
    Everything else is blank
