Activity Forums Panasonic Cameras Another P2 Error Thread
  • Another P2 Error Thread
    Posted by Josh Greenbaum on June 16, 2009 at 3:16 pm
    After searching the forum I’m surprised to have found nothing that matches the problem I’m having. I have all of my cards up in log and transfer so there are no incomplete clips. Several clips (but not all) from 2 of the cards do not transfer completely. In one example, the clip is 10 minutes long and plays through in the log and transfer preview window, but when I try to transfer it, it stops towards the end, gives me the exclamation point, and sometimes I end up with part of the clip in my capture scratch folder, and sometimes I get nothing. I tried with the remove pulldown box both checked and unchecked, and I get the same result. Any suggestions on how I can get this whole clip transferred to qt?
    thanks!
    Josh Greenbaum replied 17 years, 2 months ago 3 Members · 4 Replies
  • Josh Greenbaum
    June 16, 2009 at 9:28 pm
    I should add that I am unable to copy the contents and last clip items back onto a P2 card to attempt an in camera repair because “some data could not be read or written.” I can’t copy or duplicate it either, and I am apprehensive to run the repair clip function in HD Log on the only existing copy of this media. Still lookin for a solution…
  • Jeremy Garchow
    June 17, 2009 at 12:01 am
    How are your capture scratch drives formatted? Please look in disk utility.
  • Dave Neyman
    June 18, 2009 at 1:08 pm
    Jeremy is asking how your drive is formatted because it makes a difference. If it is formatted FAT32 it has problems transferring large clips around the 4 GB size. An easy work around until you reformat the drive is to grab the first 5 minutes or so of the clip and transfer it as part 1 then grab from that out point to the end of the clip and call it part 2. You can then string back together in the time line.
  • Josh Greenbaum
    June 18, 2009 at 2:33 pm
    Thanks for getting back. I surrendered the drive to the techs at our post house, but I believe it is Mac OS Extended (Journaled). I did try to salvage the footage in segments at a time, but I still get the same error. I’ll have to wait and see what the techs tell me later today.
    –josh
