Activity Forums Adobe Premiere Pro Another odd bug – Adding LUT only turns video flat
  • Another odd bug – Adding LUT only turns video flat
    Posted by Duke Sweden on September 10, 2017 at 12:01 pm
    Once again, since no one else has complained about this I’m sure it’s another one off, but it has happened on my old PC and on this new one. I’ll open a video shot in V Log, for example, and add an input LUT to it. Usually I try to manually grade now but sometimes I’ll play with a “finishing” LUT, if that’s what you call them, just to see what the result would be. The first one will work fine, the second, but then on the third attempt, instead of affecting the video, it turns everything flat, and if I replace it with another LUT I get the same result. The only way to get rid of this glitch is to go back to “None” but adding a LUT will still turn everything flat. It doesn’t happen all the time, but often enough.
    Anyway, I doubt there’s a solution but I just wanted to add this glitch to the pile.
    Dell XPS 8920
    Intel i7 core 7700 build
    GeForce GTX 1050ti
    32 Gigs of RAM
    3 7200 RPM SATA Drives
    Windows 10 64-bit
    Premiere Pro CC 2017 v.11.0
    Duke Sweden replied 8 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
