Activity Forums Apple Final Cut Pro Another “Find My” suggestion
  • Another “Find My” suggestion
    Posted by Mark Smith on April 20, 2022 at 4:49 pm
    Syncing up sections of audio and video clips, I’ll find a section of video that I need to sync an audio file with, copy timecode at play head location – switch to audio- file ctrl P, cmd V paste time code, return, Play head is now at the right location in the audio file and I can select the audio bit and sync the clips. In film strip view the play head location frequently is hard to locate visually , so I suggest a command that will make the play head location in the Browser flash a play head location in something bigger than a 1 or 2 pixel thick line so It can be found quickly. Sort of like using find my phone to make a misplaced phone ping so you can find it.
    Mark Smith replied 4 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
