Activity Forums Apple Final Cut Pro Legacy Another Final cut sync problem
  • Another Final cut sync problem
    Posted by Marc Daniel villarin on July 14, 2008 at 3:06 am
    I have a problem with our final cut pro. Our footages are out-of sync. In the timeline, the waveforms seems are correct. But if we playback the whole timeline, the audio becomes delay at the end. I tried clearing the preference setting but no dice.
    What could be my opinions.
    Here are our specs
    Machine Name: Power Mac G5 Quad
    Machine Model: PowerMac11,2
    CPU Type: PowerPC G5 (1.1)
    Number Of CPUs: 4
    CPU Speed: 2.5 GHz
    L2 Cache (per CPU): 1 MB
    Memory: 6 GB
    Bus Speed: 1.25 GHz
    VIDIA GeForce 7800GT:
    Chipset Model: GeForce 7800GT
    Type: Display
    Bus: PCI
    Slot: SLOT-1
    VRAM (Total): 256 MB
    Vendor: nVIDIA (0x10de)
    Device ID: 0x0092
    Revision ID: 0x00a1
    ROM Revision: 2152.2
    Thank you for help in advance
    https://www.youtube.com/user/marcdanielvillarin
    Look on the Bright Side…
    Alfi Randy replied 18 years, 2 months ago 3 Members · 2 Replies
  • Kevin Monahan
    July 14, 2008 at 4:31 pm
    This is usually a case of your speakers set up incorrectly. Are they connected out of the Mac or out of the deck?
    Kevin Monahan
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • Alfi Randy
    July 15, 2008 at 10:12 pm
    The delay that you’re hearing is most likely a result of how your speakers are connected and the length of the cables you’re using. The best way to tell if everything is in sync, is to playback your video using an external monitor. So, output your video to your deck and onto an external monitor that has built in speakers.
    Serenity now…
