Activity Forums Creative Community Conversations Another FCPX Feature Request
  • Another FCPX Feature Request
    Posted by Lance Bachelder on June 5, 2013 at 4:43 pm
    This one is so basic and hard to believe it’s not been fixed in one of the 8 updates Apple has released:
    When re-linking files, X needs to be able to index and search entire volumes including folders and subfolders. Currently you must manually navigate to the requested folder and then it will search that folder. This is such a pain and not “pro” at all. Sony Vegas has always had the best indexing and searching function – it will search and index every single file on a drive no matter how far it has to drill down and give you a list of matching names and it does it lightning fast.
    It would be nice to just point to a volume where you know your files exist and let FCPX find all the files on that volume no matter how they are structured. This would make sharing jobs much easier too.
    Lance Bachelder
    Writer, Editor, Director
    Downtown Long Beach, California
    https://www.imdb.com/name/nm1680680/?ref_=fn_al_nm_1
    Scot Walker replied 13 years, 3 months ago 7 Members · 24 Replies
  • 24 Replies
  • Jeremy Garchow
    June 5, 2013 at 6:18 pm
    You can drag a folder from the Finder to the Event icon in FCPX.
    You should get a little bent arrow when doing so, otherwise, you will get a green plus sign.
    A bent arrow will reference any connected media, a green arrow will copy media in to the Event.
    Holding option should override copy or reference, changing the icon in the process.
    You wouldn’t want to do this on a while volume, however, as then every importable file would import in to your event.
    You would want to do this if your files are organized in the volume by specific Event(s).
    I agree that this process could be better, but it can also do what you need as long as you know what to do.
    Sometimes dragging and dropping is the easiest way to relink, you just have to know the caveats.
    Jeremy
  • Lance Bachelder
    June 5, 2013 at 6:47 pm
    This doesn’t address the issue at all. In your method you still need to drag a specific folder to the Event. Will this method search sub-folders that may be in the folder? FCPX creates a folder called Original Media inside every event folder and sadly cannot find this on it’s own.
    Regardless of how well your method works for you, FCPX re-link still needs to be able to index a complete volume including folders and subfolders and find and re-link files wherever they may live.
    Lance Bachelder
  • Jeremy Garchow
    June 5, 2013 at 6:56 pm
    I don’t know how you organize your footage.
    Let’s say it’s in a folder called “footage” and in that folder is a bunch of sub folders.
    You can take the “footage” folder, drag it to the appropriate Event icon, and choose, with the option key, to re-alias the media, or reimport the media in to the Event. Either way, the footage will relink.
    I understand you are pissed, but you don’t seem to be trying to use FCPX for the way it works, you instead are trying to force it to work like FCP7 and failing.
  • John Davidson
    June 5, 2013 at 7:02 pm
    Lance, if you do a search for the first file in the list of files your reconnecting/relinking and type it in I think in the spotlight column at the top right (I think) and relink that one file, all files within the list reconnect assuming they’re ‘near’ the file you link to. Right?
    John Davidson | President / Creative Director | Magic Feather Inc.
  • Lance Bachelder
    June 5, 2013 at 7:44 pm
    Yes it will re-link all files within a folder – but you must point to that folder. You can’t just point to a drive and let it search all ht e folders etc like 7 or Vegas can.
    I know there are some workarounds but this is still not acceptable – relink function should be able to drill down as necessary to find all missing files in my opinion.
    Lance Bachelder
  • Lance Bachelder
    June 5, 2013 at 7:50 pm
    Like I’ve said – all my current headaches are this feature film that was handed to me from another Editor who used FCPX and built a complete mess – all I’d like to do is get a clean timeline as ONE Event or Project that leaves all the 50+ Events behind so I can hit space-bar and wait up to 6 seconds to begin playing.
    Copied and pasted final timeline into new comp in a new Event – of course all media offline when you re-launch via Event Mgr. This is fine but re-linking is a disaster – even when FCPX found several hundred files when I clicked re-link and came back 3 hours later it was only 23 files in! Sucks…
    Lance Bachelder
  • Erik Lindahl
    June 5, 2013 at 7:55 pm
    IMO OSX and FCPX with it should have more of an “understanding” of all the files in the system. Spotlight indexes everything so a FCPX project should instantly be able to find a clip based on name and meta-data. At the rare occasion of duplicate clips it could ask what file to use.
    I’m quite amazed this hasn’t happened. It was one of the first things I thought would happen with the introduction of Spotlight almost 10 years ago.
    Adobe products are equally “stupid” in this regard.
  • Jeremy Garchow
    June 5, 2013 at 8:06 pm
    Lance.
    It’s like you aren’t even hearing me. Here are the spelled out steps.
    If your final timeline is a compound, copy and past it in to a new Project, or add the compound to a new Project and break it apart.
    Open the Project Library and choose the final timeline.
    Select it and choose to Duplicate Project (command-d)
    Choose a location (perhaps a new hard drive) from the drop down menu
    Then choose the third option “Duplicate Project + Used Clips”
    Use the “All used clips” option.
    Type in a new name for the Event.
    Here’s a picture
    Now hit OK:
    This will create a new Event and new Project with only the clips you used in the final timeline at the destination of your choosing.
    Now, select that new Event in the browser.
    Choose File > Organize Event Files.
    You’ll get something that looks like this:
    Watch the background processes and you will see the files being copied over. Once they are done, you can quit FCPX, eject the original drive, and open a cleaned Event and Project.
    jeremy
  • John Davidson
    June 5, 2013 at 8:07 pm
    Let’s hope something like that gets incorporated into 10.9 “Sex Panther”.
  • Jeremy Garchow
    June 5, 2013 at 8:11 pm
    [Erik Lindahl] “IMO OSX and FCPX with it should have more of an “understanding” of all the files in the system. Spotlight indexes everything so a FCPX project should instantly be able to find a clip based on name and meta-data. At the rare occasion of duplicate clips it could ask what file to use. “
    Andreas Kiel has utility that will help in this regard:
    https://www.spherico.com/filmtools/
    Then click on the “myFiles” option.
Page 1 of 3
