Activity › Forums › AJA Video Systems › Another CYA Q: K3 + MP Octo upgrade
  • Another CYA Q: K3 + MP Octo upgrade
    Posted by Steve Covello on September 4, 2007 at 11:45 pm
    Current setup:
    G5 2.0 DP [2003] PCI-X 4gb RAM, 10.4.9, FCP 5.1.4. with Apple fibre [copper], Kona 2, to XServe RAID 50 2.5 TB.
    On second internal HDD: FCS2, 10.4.10
    Looking to upgrade to MP 8-core, Kona 3, PCIe Fibre Card, XServe RAID 50 [same RAID}
    Anything else I should expect to acquire? Only other option I think would be the HD10AMA for audio conversion.
    Would the RAID need to be reformatted for any reason? Any minimum RAM suggestions? I figure 4 or 6gb should be enough.
    thx.
    steve covello
    double wide post
    Walter Biscardi replied 19 years, 1 month ago 2 Members · 1 Reply
  • Walter Biscardi
    September 4, 2007 at 11:49 pm
    The RAID should not need to be reformatted for any reason, but absolutely back up everything on that array before you make the switch, just in case. Might not be a bad idea to simply wipe that array clean and then put all the media back on it when you make the switch.
    Absolutely, positively don’t switch machines until you’re at a comfortable place in your production schedule to deal with any unforseen issues. Better yet, if there’s a way to start running your new machine while keeping your old machine active at the same time, that’s the best way to make the transition. I was able to do that with our transition to the Mac Pro.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
