Activity Forums Apple Final Cut Pro Legacy another 1080i/24pa question. Yikes but easy.
  • another 1080i/24pa question. Yikes but easy.
    Posted by Michael Unger on January 28, 2009 at 5:55 am
    Im shooting 1080i/24PA footage. Now in FINAL CUT PRO 5.1
    What should my _______be?
    1. EASY SETUP
    2. SEQUENCE SETTING SETUP
    3. CAPTURE SETTING SETUP
    there is no 1080i/24PA setup in final cut pro 5
    thanks.
    Chris Poisson replied 17 years, 7 months ago 4 Members · 4 Replies
  • Jerry Hofmann
    January 28, 2009 at 2:04 pm
    Well… for starters there’s no such thing as 1080i24pa… Which camera and format are you shooting? HDV? P2? If it’s 1080p 24 (most likely it’s that) just capture it using that preset. Is this tape or?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Shane Ross
    January 28, 2009 at 4:27 pm
    [Jerry Hofmann] “or starters there’s no such thing as 1080i24pa…”
    IS TOO…IS TOO! My HPX-170 P2 camera has this setting. Shoots 1080i at 29.97, but the 24pA setting means that I can remove pulldown on ingest and get 23.98 at 1080p.
    But yeah…we need to know what format dude!
    Shane
  • Michael Unger
    January 29, 2009 at 7:52 am
    Im shooting with p2 cards. Also the hvx200 has a 1080i/24pa setting, this is so you can edit in a true 23.98 sequence in final cut pro but im using final cut pro 5 so there is no setting for 1080i/24 24pa for that matter. All im seeing is 1080i/60 1080i/30.
  • Chris Poisson
    January 29, 2009 at 3:34 pm
    I’m just guessing here, but try manually changing the sequence settings at the start when you create the sequence. You can only change the frame rate right at the start, but it might work.
    Have a wonderful day.
