Activity Forums Avid Media Composer Annoyance: Match frame without pushing alt
  • Annoyance: Match frame without pushing alt
    Posted by Benjamin Steiner on April 9, 2015 at 11:42 pm
    I have chosen Y for “match frame”, but match frame by default destroys the Mark In. If you push Alt with it, it leaves the Mark In unchanged.
    I would like Y to actually do Alt+Y “match frame without changing mark in”.
    Is that possible?
    Benjamin Steiner replied 11 years, 5 months ago 2 Members · 2 Replies
  • Shane Ross
    April 9, 2015 at 11:58 pm
    Go into the COMMAND PALETTE, choose the OTHER tab. Now also map the OPTION key to the Y key…then it should do what you want. I do this with the C command. I don’t just want what I selected put in the clipboard, but I want it immediately put into the PREVIEW monitor. To do that you press ALT/OPTION-C. But I mapped OPT to C as well and now it does it with one push of the button.
    Shane
    Little Frog Post
  • Benjamin Steiner
    April 10, 2015 at 12:19 am
    thanks, that’s great news, didn’t see this “add alt key” button in Other. But it doesn’t work for me (I am on PC), when I drag the Add Alt button to Y it doesn’t do anything…
