Activity Forums Avid Media Composer Animatte tutorial
  • Animatte tutorial
    Posted by Kubelik on November 24, 2007 at 1:47 pm
    Hello
    Could someone recommend a tutorial [text or video] for using the Animatte effect? I want to blur out something and for some reason my brain freezes when I try to work out the effect.
    Jon Zanone replied 18 years, 10 months ago 2 Members · 1 Reply
  • Jon Zanone
    November 26, 2007 at 12:42 pm
    First, I would suggest the paint effect, not animatte. Paint allows you to assign a blur, mosaic, etc. to your effect.
    (Please keep in mind I’m writing this from memory…)
    Apply the effect. Open the effect editor. Toward the middle of the editor, you’ll see a pulldown menu. Select whatever effect you’d like to see (mosaic, for example). On the right hand side, toward the bottom, you’ll see a square (and other shapes as well). Make sure you have the blue line sitting on the first key frame, and DESELECT THE LAST KEYFRAME (caps for emphasis – if you don’t , you’ll run into the annoyance of having the paint effect moving back toward the original location). Click (for our purposes) the square, click and drag on the record side monitor – it should show up as a mosaic. Now comes the tedious part – key framing.
    Post if you need more help!
    Jon
    “So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
    Del Amitri – “Make it Better”
