Activity Forums Avid Media Composer Animatte Tracking of Two Elements to Each Other?
  • Animatte Tracking of Two Elements to Each Other?
    Posted by Nina Lucia on September 3, 2015 at 10:02 pm
    I have two takes of the same shot (window in bg that needs to be replaced), both of which are moving around quite a bit. I need to take the window from one and put it into the other.
    I have gotten the tracking for the cut out I made in animatte for the fg layer. Now I need to figure out how/if I can use tracking to get the window of the second element, the other take, to go into the cut out area of the fg shot.
    Is there a way to do that? To track the bg shot with the fg shot?
    Thanks.
    Nina Lucia replied 11 years ago 3 Members · 4 Replies
  • Shane Ross
    September 3, 2015 at 11:27 pm
    You’ll find that Avid is a very poor compositing application. This is something best done in After Effects. Avid can be made to do a great many things. But what you are attempting…alas…isn’t one of them.
    Shane
    Little Frog Post
  • Nina Lucia
    September 4, 2015 at 2:27 am
    Thanks Shane!
    Don’t know After Effects yet so we’ll see what I come up with. Maybe 567 key frames. 🙂
  • Alain Dessauvage
    September 6, 2015 at 12:27 pm
    Not true Shane, Avid’s compositing tools are quite good: tracking and stabilization, keyframeable garbage mattes with bezier splines etc.
    What you need to do:
    – put the background on V1 and the foreground on V2
    – stabilize the foreground using the Region Stabilize filter. You should be able to completely lock the foreground element otherwise things will get difficult
    – alt drag the 3D warp filter on V2 and the select the tracking module
    – track the background using one or two tracking points. The second one is necessary if also tracking rotation or scaling
    – enable the tracking and reposition the foreground element on the background
    – crop your foreground element. If you need a more precise crop, alt drag the animatte filter and create a custom shape
    – this shape can then be tracked as well, if necessary.
    To my knowledge, Avid is the only NLE that enables this kind of composition work without leaving the software
    https://www.imdb.com/name/nm0220918/
  • Nina Lucia
    September 15, 2015 at 8:11 pm
    Thanks for the tip Alain.
    One thing though, I do not want to stabilize the fg. That shot is good as is. Is there a way to do the shot without that step? Stabilize the bg then track it to the movement of the fg shot?
    I have time to play around with it now so I’ll try what you mentioned without stabilizing the fg and see what happens.
    So I ended up manually keyframing the bg and for a 307 frame shot I have 59 keyframes. It jiggles a little bit but it’s not too bad!
