Activity Forums Apple Final Cut Pro Legacy Animation/Prores mix outputting to Flash
  • Animation/Prores mix outputting to Flash
    Posted by Adrian Lort-phillips on November 22, 2011 at 2:50 pm
    Hello
    I am editing a film on a prores timeline (PAL 720×576 16:9). It is going to end up as an FLV online, probably 640×360.
    The filming was done on a mixture of Digibeta and DVCam, converted to ProRes then imported. Crucially there are also some animated sections to import and insert, some of which dissolve into the footage.
    I have asked the animators to provide files in Animation codec which they have in 1024×576 around 11MB/s.
    I am having problems with the animated section. They don’t sit well on the timeline looking blurred when rendered. (maybe they should have sent them to me 720×576?) That carries through to the FLV of course. If I compress them into FLV on their own they look fine.
    However ultimately they will be part of the whole online. How can I mix these two elements together and maintain the progressive integrity of the animations? Any thoughts much appreciated.
    Adrian
    Adrian Lort-Phillips
    Radiant Media
    http://www.radiantmedia.co.uk
    Adrian Lort-phillips replied 14 years, 9 months ago 2 Members · 5 Replies
  • Adrian Lort-phillips
    November 22, 2011 at 3:18 pm
    UPDATE
    Taking the mountain to.. the man, I tried exporting my film footage into animation codec and then added them and the animated sequences onto a new animation codec timeline. Big files obviously but a much better result when compressed into flash. Is this the only way forward?
    Radiant Media
  • Rafael Amador
    November 22, 2011 at 3:30 pm
    And why don’t you get your animation in Prores444 and put everything in a 1024×576 sequence.
    Make the sequence Progressiove and de-interlace the footage.
    Set as well “Render all YUV in High Precision”.
    rafael
    http://www.nagavideo.com
    November 22, 2011 at 3:55 pm
    Hi Rafael
    [Rafael Amador] “And why don’t you get your animation in Prores444 and put everything in a 1024×576 sequence.
    Set as well “Render all YUV in High Precision”.”
    Just to be clear:
    Get the animator to export in ProRes444
    Put everything in a 1024×576 sequence – so, a prores444 sequence mixing that animated prores444 and the standard prores together?
    Make the sequence progressive – how? by setting fields to ‘none’?
    Many thanks
    Adrian
    Radiant Media
  • Rafael Amador
    November 23, 2011 at 1:09 am
    [Adrian Lort-Phillips] “Get the animator to export in ProRes444”
    Yes. Better than Animation which i guess you are using because the Alpha Channel.
    [Adrian Lort-Phillips] “Put everything in a 1024×576 sequence – so, a prores444 sequence mixing that animated prores444 and the standard prores together?
    Make the sequence progressive – how? by setting fields to ‘none’?”
    You are going to the web so in the end you have to convert everything to Squared Pixels and Progressive.
    Start with a sequence like that: 1024×576/SQ Pixels/ Field Order NONE.
    You only need to deinterlace the video footage before exporting.
    If you edit in Pal and add your 1024×576 graphics, those will be converted to Pal (720×576 Interlaced) in the time-line and you will need to re-convert again to SQ pixels for the web.
    Things like dissolves, wipes, or any kind of animations that is rendered as Interlaced will look worst after de-interlacing.
    Render everything as Progressive.
    rafael
    November 23, 2011 at 8:39 am
    Thank you Rafael,
    That is very helpful.
    Adrian
    Radiant Media
