Activity Forums Adobe After Effects Animation with lip sync at 15 fps, client now wants video at 30 fps
  • Animation with lip sync at 15 fps, client now wants video at 30 fps
    Posted by Teresa Dey on April 16, 2015 at 6:45 pm
    If I just change the framerate in the composition, the exported video’s lip sync is off. Is there any way to do this without having to go in and re-do the lip sync animaton?
    Many thanks.
    Tudor “ted” jelescu replied 11 years, 4 months ago 2 Members · 1 Reply
  • Tudor “ted” jelescu
    April 21, 2015 at 3:08 pm
    Don’t change the frame rate of your composition – create a 30 fps comp. Drag your original audio in. Drag your 15 fps comp in. Enable time remap on the 15fps comp layer. Extend to the expected length in 30 fps (should be double). This should create the in-between frames for you.
    Tudor “Ted” Jelescu
    Senior VFX Artist
