Activity Forums Adobe After Effects Animation Loop Problem
  • Animation Loop Problem
    Posted by Ardelean Alex on October 4, 2009 at 5:10 pm
    I have created a fire using a particle generator (CC Particle World) which randomly generates the particles… I need a short animation of a fire that loops, but I can`t get the last frame to match the first… I don`t even know if it`s possible with this sort of animation… Is it?
    Any help would be apreciated 🙂
    Jeremy Fabiano replied 16 years, 11 months ago 2 Members · 1 Reply
  • Jeremy Fabiano
    October 4, 2009 at 11:58 pm
    export the animation, import it and loop it in the interpret footage dialog
    OR
    Apply time remapping to the layer.
    Extend its out point to the end of your comp.
    Reveal the time-remapping keyframes.
    Alt-click (opt-click) on one of them to set up an expression.
    Select the little triangle to reveal the expression menu, then
    under “property”, click the loop out expression:
    “loop_out(type = “cycle”, num_keyframes = 0)”.
    -Jeremy
    If you didn’t supply enough information I will start making assumptions. I’m usually wrong when I assume.
