Animation Library
Hi guys
Do any of you know if there exist a plugin for After Effects where its possible to save certain animations you have done for a character as a preset in a Database or Library so I can reuse them in another .aep with the same character?
For instance if I make a walk cycle for the character and I only want to reuse how the legs move, I would select the keyframes from a certain range and save it as a preset in the library. In the next after effects project I want to paste in the exact same legs movement and I would like to put the marker on the timeline select the preset in the library and then it would automatically paste in the keyframes from that point in the layers with the same names as the once I chose in the previous after effects project.
If it exists it would be awesome, otherwise are any of you for hire to program such a plugin?
Kind Regards
Rune
