  • Posted by Russ930 on March 17, 2007 at 5:21 am
    I have a series of stills that make up an animation that is overlayed on an actual photo. Is it possible to scale all of the stills at the same time?
    Thanks in advance.
    Russ930 replied 19 years, 5 months ago 3 Members · 3 Replies
  • Thaxter Clavemarlton
    March 17, 2007 at 5:34 am
    Each still is a separate clip.
    Just scale the first clip correctly,
    then Apple-C (copy) it
    then select ALL of the rest of the clips on that same track and
    hit Option-V (paste attributes) and
    choose “Basic Motion” and/or any of the other boxes that you want.
    All of the rest of the clips will then match the first one’s adjustments.
  • Debe
    March 17, 2007 at 5:29 pm
    Or just use the Nest command and put all the stills in one “container” that you can then adjust as one clip.
    debe
  • Russ930
    March 17, 2007 at 11:37 pm
