Activity Forums Adobe After Effects Animating the scale of a motion path [solved!]
  • Animating the scale of a motion path [solved!]
    Posted by Brian Nishii on December 9, 2017 at 12:11 am
    I have a flare parented to a null that is moving along a motion path.
    Is there anyway to animate the scale of the motion path while the flare is moving along the said path?
    I know you can copy/paste motion motion path to shape path and scale, but to animate it?
    [EDIT]
    In case anyone stumbles onto this, I found an elegant solution to what I wanted to do using Dan’s space transformations here:
    So,
    1) “TargetNull” follows a motion path inside a PreComp.
    2) PreComp is resting in a MasterComp with collapse transformations.
    3) “FollowNull” will follow the TargetNull with these expressions in position parameter:
    L1 = comp(“PreComp”).layer(“TargetNull”);
    P1 = L1.toWorld(L1.anchorPoint);
    L2 = thisComp.layer(“PreComp”);
    L2.toWorld(P1);
    Now, I can scale the PreComp inside the MasterComp, and my FollowNull will follow nicely!!
    As always, Mr. Ebberts is the KING!
    Brian Nishii replied 8 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
