Activity Forums Apple Final Cut Pro Animating splitscreens in FCPX
  • Animating splitscreens in FCPX
    Posted by Helena Masterson on June 10, 2014 at 2:29 pm
    I’m working on animating some splitscreens in FCPX 10.0.9 and for some reason it won’t let me keyframe the trims I have. I understand keyframing and am doing it exactly the same way as I always do, but for some reason the footage/trims will not animate on screen – even though the parameters are changing in the inspector and the keyframes are showing in the video animator on the timeline.. Am I missing something or is this a bug?!
    Helena Masterson replied 12 years, 3 months ago 3 Members · 4 Replies
  • Mark Morache
    June 10, 2014 at 2:56 pm
    Are you still in the animation mode in the source screen? Sometimes I don’t see what’s actually happening until I press “DONE” in the browser screen.
    If all else fails, I reset the motion parameters of the clip (or replace the clip in the timeline with a clean version from the event browser) and start over.
    Don’t live your life in a secondary storyline.
    Mark Morache
    FCPX/FCP7/Xpri/Avid
    Evening Magazine,Seattle, WA
    https://fcpx.wordpress.com
  • Helena Masterson
    June 10, 2014 at 4:24 pm
    Thanks Mark. I tried your suggestions but they don’t seem to be fixing the problem. It’s strange as the ‘position’ keyframes work fine, it’s only the ‘trim’ keyframes that don’t seem to be working!
  • Eric Santiago
    June 10, 2014 at 7:22 pm
    Sounds like a bug.
    I ran into something like this where all my changes did not update on screen.
    Eventually after a reboot, the edits occurred.
  • Helena Masterson
    June 11, 2014 at 9:54 am
    Thanks for the reply Eric. I think you may be right! I’ve tried everything – setting the keyframes then rebooting.. Nothing has worked. I have to say I’m pretty disappointed with the software in regards to how many bugs it has..
    Thanks again.
