Activity › Forums › Adobe After Effects › animating smoke?
animating smoke?
Posted by Leesa Dean on October 29, 2006 at 1:26 pmHi,
Can any suggest a good plugin to animate very realistic smoke? I checked out the tutorial using the particle playground and wasn’t crazy about the way the smoke looked. I’m a mac person, using an intel-based mac.
Thanks.Leesa Dean replied 19 years, 10 months ago 3 Members · 6 Replies -
Jonathan Pitzer
October 30, 2006 at 1:46 pmIt is very easy to make animated smoke using fractal noise on a layer and then changing the blending mode. I believe that there is a tutorial on this in the cow but I could be wrong. It is pretty easy though, just play around with it.
Leesa Dean
October 30, 2006 at 3:58 pmThanks. I’ll check it out. I also downloaded the delirium plugin demo from digieffects, which looks pretty good.
Michael Duff
October 31, 2006 at 9:49 pmif it’s not realistic enough for you have you considered using real footage of smoke? You could purchase stock footage or shoot some smoke against a black background and then use a transfer mode to composite it.
will render faster too….
just a thought…..
Jonathan Pitzer
November 1, 2006 at 1:35 pmIf you are going to consider that route, this site has several versions shot against a green screen for you.
https://www.detonationfilms.com/free_stuff.htm
However, making it yourself gives you much more control over it.
