Activity › Forums › Adobe Premiere Pro › animating position in multiple images as a group
  • animating position in multiple images as a group
    Posted by Guido Garf on July 1, 2015 at 5:30 pm
    Hi all,
    This is hard to explain…
    I have several images that match between each other. I have a transition between all of them, and now I want to move them vertically while keeping their relative position the same.
    For example, I have several images(clips) with a circle, same size in all of them. The color changes though.
    Now I want to move all the images together vertically while keeping the circles aligned.
    – Copy/paste doesn’t seem to maintain the overall animation, no?
    – I tried animating a track that goes from the beginning to end. Didn’t work.
    – Nesting: crops the whole group to the size of the sequence.
    Any ideas?
    Guido Garf replied 11 years, 2 months ago 2 Members · 2 Replies
  • Ann Bens
    July 1, 2015 at 10:22 pm
    Copy one and Paste Attributes on the rest.
    Adobe Certified Expert Premiere Pro CS6/CC
    Adobe Community Professional
  • Guido Garf
    July 1, 2015 at 10:54 pm
    Thanks, but that would make each image to move from and to the same location as the previous one.
    Basically, I want to mix a series of images that transition between each other, and a translation movement for the whole set if images.
    I solved the problem by creating a new sequence and then animating that sequence.
