Activity Forums Adobe After Effects Animating portions of a pattern to change color
  • Animating portions of a pattern to change color
    Posted by Carlos Panades on January 26, 2017 at 12:42 pm
    I want to create a hexagonal pattern to fill a Mundi Map, just like the map of War Board Game (https://paxsims.files.wordpress.com/2012/07/pic169697_lg.jpg).
    I would like to know a way to animate some of those hexagons to have a different color in a given time and be able to control the amount of the ones that will be changing. Do anyone knows a technique that allows me to achieve that without need to manually select and animate each one of them?
    Thank you.
    Phil Aupperle replied 9 years, 7 months ago 3 Members · 2 Replies
  • Walter Soyka
    January 26, 2017 at 4:10 pm
    We’ve done hex patterns like this with two offset/interlocked layers of Trapcode Form. Use a custom hex-shaped particle, and use the layer maps feature to color them according to a regular image.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Phil Aupperle
    February 2, 2017 at 5:20 pm
    I’ve done effects like this by creating the hex pattern in Illustrator and converting to shape layers in AE with the Explode Shape Layers script ( https://aescripts.com/explode-shape-layers/ ) and then hooking whatever parameters you want; fill color, opacity, size, etc. to a control layer via a sampleImage() expression. You could also make the hexagons by pasting from Illustrator into masks, or just coloring Illustrator layers with the Fill effect, but you’ll have a separate layer for each hexagon with those methods. There is also a script called Divide and Corner that will create the hex-pattern as shapes in AE. If you’re working with tons of shape layers, I recommend having the Explode Shape Layers and Motion2 scripts to wrangle them and manage the anchor points.
    Here’s dan’s guide to using sampleImage():
    https://www.motionscript.com/design-guide/obscuration.html
    Cheers
