Activity Forums Adobe After Effects animating opacity with expression using source black & white lines
  • animating opacity with expression using source black & white lines
    Posted by Pradeep Naidu on July 26, 2015 at 4:12 pm
    hi guys i wanted to make some video loops i’m successfully making it but it consumes lot of time
    from past 1 month i have created only 5 loops idea consist of 50+ loops
    here’s what i’m doing
    https://images.creativecow.net/299442/bulbon.png [main comp]
    now since it’s taking lot of time i would like to use this animated white lines made in ae itself like this
    https://images.creativecow.net/299442/whiteline.png [source comp]
    so my idea is using this layer as source to animate the opacity the main comp using expression
    can you guys help me out with expressions i need
    thank you in advance
    Peter Diefenthaler replied 11 years ago 2 Members · 1 Reply
  • Peter Diefenthaler
    July 26, 2015 at 5:33 pm
    Do the white lines in the source comp consist of individual layers with opacity property? If so, put this expression in the opacity property of one layer, copy expression only and paste to all other layers in the main comp. It will copy the opacity of the white shapes based on layer order.
    comp("source comp").layer(index).transform.opacity
    Peter Diefenthaler
    https://www.ideafirecreative.com/
