Activity Forums Zaxwerks Animating Materials
  • Animating Materials
    Posted by Banshee on June 22, 2005 at 4:09 pm
    Hello again,
    Can someone tell me how I can change the color of a material during an animation?
    What I want to do is a text with 3D Invigorator that is yellow at first, then blends to blue, then to green, etc.
    Thanks for every help!
    Banshee replied 21 years, 3 months ago 2 Members · 2 Replies
  • Matt Rhodes
    June 22, 2005 at 6:22 pm
    Hi Banshee.
    At this point the Invigorator doesn’t support animated colors.
    However, by cleverly using Layer Maps, you can animate the materials.
    The (abbreviated) steps would be:
    – Create a secondary Comp (call it Comp B) that is just a Solid with an animated color.
    – Add Comp B to your main Comp and turn off its visibility.
    – Find the “Layer Map 1” parameter for the Invig layer and select “Comp B”.
    – Open the Invig Options window and create a new material using Layer Map 1 for the color map.
    – Assign that new material to your text objects and close the Options window.
    – Your text should now use the colors from Comp B.
    You can use a similar technique for animated bump maps, specular maps, reflections, etc.
    Let us know if you need more assistance.
    Matt Rhodes
    Zaxwerks, Inc.
  • Banshee
    June 23, 2005 at 9:22 am
    Wow,
    at first it sounded very tricky to me but I made it within the first try. Really nice effect,
    Big thanks :]
