Activity Forums Adobe After Effects Animating material to look like FLAG!
  • Chris Wright
    June 24, 2008 at 7:38 am
    tinderbox can do flags
  • Joseph W. bourke
    June 24, 2008 at 1:43 pm
    The tutorial looks pretty straightforward to me, but you do have to have the Forge Freeform plugin to achieve it Ayato’s way. A simpler way, but not as good looking, is to simply use a Fractal Noise map in which the phase is moving from left to right (the way wind ripples do in a real flag). Play around with the settings, and then apply the rendered noise file as a bump map in AE. The best way to do it, in my opinion, is to do it in 3D Studio Max using a cloth modifier and wind. There’s also a Zaxwerks plugin called 3D Flag for $129. that does the work for you:
    https://zaxwerks.com/3dflag/index.shtml
    Joe Bourke
    Art Director / WMUR-TV
  • Jamil Yamani
    June 24, 2008 at 11:44 pm
    Hi there
    thanks i had another look at it and your right, its fairly straightforward. cost wise i think its best to go with the zaxwerks plugin and the freeform guys have still got the intel version of their plugin in beta anyway.
    i couldn’t see from all the tinderbox plugins which one might be suitable to achieve the effect i was looking for.
    thanks for your advice, its very much appreciated
    The Electric Canvas
    Large Format Projection Specialists
    Sydney, Australia
