Activity Forums Maxon Cinema 4D Animating Horizontal Spacing and Roatation of MoText
  • Animating Horizontal Spacing and Roatation of MoText
    Posted by Stuart Samuels on January 24, 2016 at 9:20 pm
    Hi.
    I’ve animated the horizontal spacing of some simple MoText so it begins by being wide apart and comes to rest closer together.
    I now want to add a secondary animation with each individual letter rotating from -90 degrees on H, coming to rest back to it’s original rotation (0 degrees) at the same time as the original animation ends.
    To make this second part of the animation I need to make the MoText editable but as you’ve probably guessed, once I do this I lose the initial horizontal spacing keyframes and animation.
    Is there a way around this?
    Rohan Gopalan replied 9 years, 4 months ago 3 Members · 3 Replies
  • Adam Trachtenberg
    January 25, 2016 at 12:10 am
    Why do you have to make it editable? You can animate the Transform>Rotation parameter in the MoText Letters tab, or use a Plane Effector and animate the rotation parameter.
  • Stuart Samuels
    January 25, 2016 at 8:45 am
    That’s fantastic, thank you. The Transform controls were hidden.
    That was easier than I thought it was going to be!
  • Rohan Gopalan
    December 21, 2016 at 4:20 pm
    Hi Adam,
    I want to animate a bunch of letters, they must come through a thin tunnel and when they come out they should form the word. I want all the letters to be in the center, scattered only in Z space, and when they come out of the tunnel they take the form of the word.
    Hope I explained it well.
    Appreciate your help.
