Activity Forums Adobe After Effects Expressions Animating Expressions?
  • Animating Expressions?
    Posted by Jon Smith on January 19, 2011 at 7:23 pm
    I’m trying to figure out how to specify positions at specific times. For example: I have 2 positions that I want an object to travel between. So it starts at position A then travels to position B in 2 secs.
    This is just an example of what I’m trying to do. The Timing and positions will constantly change so I want to use an expression to define them.
    -jon
    Jon Smith replied 15 years, 8 months ago 2 Members · 3 Replies
  • Dan Ebberts
    January 19, 2011 at 8:02 pm
    Like this maybe:
    pos1 = [100,100];
    pos2 = [200,200];
    time1 = 1;
    time2 = 3;
    linear(time,time1,time2,pos1,pos2)
    Dan
  • Jon Smith
    January 22, 2011 at 2:27 pm
    Thanks you sir, That works beautifully.
    A second part to that: Is there a way to tell a parameter to be a certain value at one time and another value at another time?
    Basically similar to setting hold keyframes.
    so at
    0 sec = 100
    1 sec = 200
    but without the linear change?
    I tryed to use AE expression reference library but it’s so hard to find what I’m looking for.
    Thanks again.
  • Jon Smith
    January 22, 2011 at 3:02 pm
    I finally figured it out with a if/else stament. Thanks for the help Dan.
