Animating color change on multiple objects
I have several objects with the same color blue applied; I want to animate just *one* of those objects to the color of white, then back to its original blue…then change another one to white, then back to blue, etc. (I’m highlighting one by one)…I just cant get this to work. When I select the first object to change to white, I ctrl-click on the dot next to “color” and slide it to white at which point *all* the objects change from blue to white. I can’t get just *one* object to change…clearly I’m doing something wrong as usual…how can I do this right? (I know I can create a new keyframe for the object but it results in an “abrupt” change in color, not the smooth “tweening” effect).
thanks
