Activity › Forums › Maxon Cinema 4D › Animating between 2 materials
  • Animating between 2 materials
    Posted by Simon Hutchinson on January 19, 2009 at 9:08 am
    Hi there,
    Simple problem really, just wondering how to animate between materials. I know how to animate colours, but materials seems a different issue. It just jumps from one material to the other (no f curve).
    What am I missing?
    Thanks in advance.
    Nolan Scott replied 17 years, 8 months ago 3 Members · 2 Replies
  • Randy Johnson
    January 19, 2009 at 9:15 am
    I generally just animate the alpha.
    /randy
  • Nolan Scott
    January 19, 2009 at 10:01 am
    Well, create an object (maybe a sphere), make it editable…
    Import a few textures into the material-editor…
    At frame 0 drag the first material onto your object…
    In the Attributes, in the texture tags Material, set a keyframe…
    Move the time-slider forward…
    Drag another material into the Material window in the Attributes and set a keyframe…
    Move the time-slider forward and continue with as many materials as you like…
    Render the animation…
    All textures will slowly morph into another…
    Cheers
    Nolan
