Activity › Forums › Maxon Cinema 4D › Animating an array of individual lights
  • Animating an array of individual lights
    Posted by Hannes Nehls on January 19, 2010 at 2:21 pm
    Hi there,
    I want to animate an array of about 128 individual lights in intensity to create a oscillating (intensity only) string of light. I was thinking and tinkering about it for some time, but I didn’t come up with an idea that does not involve intense manual labour on each individual light ; (
    Still, I’d say there must be some way to do this programmatic or at least somehow more intuitive; simply I cannot find the proper approach. If you guys can think of something I do very much appreciate if you do share your wisdom.
    Thanks a lot, Best, Hannes
    Hannes Nehls replied 16 years, 8 months ago 3 Members · 4 Replies
  • Brian Jones
    January 19, 2010 at 7:34 pm
    how do you want the oscillation to be? All together? A pattern running down the lights (assuming they are linear)? Random?
  • Hannes Nehls
    January 19, 2010 at 7:44 pm
    Right, a pattern running down the lights… Any ideas? Best, Hannes
  • Adam Trachtenberg
    January 20, 2010 at 5:17 am
    Put the light in a MoGraph cloner set to grid mode and use a shader effector with color mode on and “use alpha/strengh” off, in conjunction with an animated gradient or bitmap.
  • Hannes Nehls
    January 20, 2010 at 10:50 am
    Hi Adam, Did some research on mograph, it looks very promising. Only real catch: I’m working on c4d 10 with no mograph : ( Will look further whether I can update! Best, Hannes
