Activity › Forums › Apple Motion › Animating a mask on a motion path
  • Animating a mask on a motion path
    Posted by Joe Penna on March 28, 2008 at 9:55 pm
    I have a “squiggly line” from Illustrator that needs to animate from left to right. I drew a motion path that matches it, but I’m not quite sure how to do it.
    I know you can do this in After Effects (see this tutorial here on creative cow). Can you do it in Motion?
    Joe
    Don Smith replied 14 years, 1 month ago 4 Members · 5 Replies
  • Joe Penna
    March 29, 2008 at 12:11 am
    Update: I just animated a freehand bezier curve (which works), but I still wonder if the motion path mask thing could still work…
  • Burt Hazard
    March 29, 2008 at 2:01 pm
    Well yeah, just like in AE you can do reveals by animating Motion’s masks over time.
    But an easier method is to use the Write-On behavior: Add Behavior>Shapes>Write On
    And you can also use the Sequence Paint behavior if your using Motion 3’s new Paint Strokes feature.
    And there’s even a script for converting Illustrator shapes to Motion shapes: https://www.motionsmarts.com/downloads.html 🙂
  • Don Smith
    August 19, 2012 at 2:36 pm
    The MotionSmarts site no longer exists because it was hosted on MobileMe.
    Can someone post that script OR list the steps it accomplished so I can try to replicate it?
    NewsVideo.com
  • Mark Spencer
    August 19, 2012 at 2:55 pm
    Here you go
    https://www.applemotion.net/downloads/
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
  • Don Smith
    August 19, 2012 at 4:52 pm
    Thank you Mark!
    NewsVideo.com
