Activity › Forums › Maxon Cinema 4D › Animating a linear fade in Cinema4D
  • Animating a linear fade in Cinema4D
    Posted by Joey Judkins on December 29, 2010 at 6:00 pm
    Hey everyone,
    I’m trying to fade up a mograph text object using a slow linear fade, much like the “slow fade on” animation preset in After Effects. I’m not sure I know how this is done, since when I mess with material settings and alpha channels, I’m not getting anywhere close to the results I need.
    Is there a simple way to mask out parts of an object, and have a feather on the mask? I’m having a hard time translating my After Effects mind to Cinema 4D on this one.
    Thanks –
    JJ
    Joey Judkins
    Motion Graphics and Video
    http://www.jjmotion.com
    Adam Trachtenberg replied 15 years, 9 months ago 3 Members · 3 Replies
  • Randy Johnson
    December 29, 2010 at 8:52 pm
    You are looking for the Display tag.
    /Randy
  • Joey Judkins
    December 29, 2010 at 9:02 pm
    Hey Randy
    The display tag, as far as I know, only allows you to go from 0% to 100% across the entire object. There’s no feathering or masking.
    How do I get a slow linear fade (like a track matte that travels across the object) to fade it up over time?
    -JJ
    Joey Judkins
  • Adam Trachtenberg
    December 29, 2010 at 10:02 pm
    You could use an animated gradient in the material’s alpha channel.
