Activity Forums Adobe After Effects animating a line between the anchor point of two objects
  • animating a line between the anchor point of two objects
    Posted by Jonathan Steele on May 25, 2010 at 12:25 am
    I have been looking in the forums but have had no luck, I am sure it is here somewhere because the idea is vaguely familiar to me. Perhaps someone can point me in the right direction.
    I need to animate a line that connects two objects two objects which of course are moving. So I am hoping for a method that does not require me to key frame all of the animations. I am pretty sure I have seen a tutorial explaining how to link each end of the line to an anchor point, but I have no idea if this is real or just a late night fantasy.
    Any thoughts on this would be greatly appreciated.
    Andrew Hoeveler replied 16 years ago 3 Members · 3 Replies
  • Todd Kopriva
    May 25, 2010 at 5:19 am
    One way is to link the effect control points for the Beam effect to the anchor points of the layers.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Jonathan Steele
    May 25, 2010 at 3:48 pm
    Worked beautifully thank you!
  • Andrew Hoeveler
    August 26, 2010 at 5:59 pm
    How can I get this to work for 3D layers? I’ve found a post here on creative cow: https://forums.creativecow.net/thread/227/8511
    But I couldn’t understand the Korean, even when using Babelfish, to get it working.
    Then I found another post: https://forums.creativecow.net/thread/227/6984#12077
    But the expressions were out of context, and it didn’t work when I tried.
    I’m surprised After Effects doesn’t just have it in the default tools to draw a line between two points in 3D. That seems pretty basic.
    I have 3D stroke as well, but not sure how to program that.
