Animating a light based on AE keyframe data
Hi everyone,
I’m trying to animate a light bulb in C4D using audio keyframes from After Effects. I took my audio file and used AE’s native ‘audio to keyframe’. I was then able to import the values as an ASCII animation import.
I can see the keyframe data in the timeline, but i can’t see how to access it. Ideally, I’d use a range mapper in Xpresso, but Xpresso doesn’t see the import data. I’ve also tried copying the keyframe data out to a Null but no luck either.What am I doing wrong?
Graham
http://www.YouTube.com/ShiveringCactus – Free FX for amateur films
