Activity › Forums › Apple Final Cut Pro › Animated Mask stopped working
  • Animated Mask stopped working
    Posted by Declan Smith on October 26, 2017 at 6:38 pm
    I have an FCPX library with a bunch of assets and a number or projects. The projects consist of muti-camera shots of a conference with a powerpoint on stage. I have replaced the filmed power point with a scaled computer quality original on a lane above scaled to cover the original presentation. All is good until speakers change and someone walks past the slide of course!! I have addressed this with an animated mask on the inserted image, all is good and works as expected on my laptop.
    I have then exported the event XML from my laptop and imported into the desktop project. When I play the project, the speakers end up behind the image file. When I stop play and click on the computer image version, and skim, I can see the mask points all animating. So it is there, but it’s not applying any alpha characteristics to the clip below. The laptop one works, the desktop one doesn’t.
    Anyone got any pointers?
    Declan Smith
    https://www.madpanic.tv
    FCPX / Adobe CS6/ FCS3 / Canon XLH1 / Canon 7D / Reason / Cubase
    \”it\’s either binary or it\’s not\”
    Declan Smith replied 8 years, 11 months ago 2 Members · 2 Replies
  • Noah Kadner
    October 26, 2017 at 8:04 pm
    It’s not inconceivable those parameters do not exist in FCPXML. For maximum fidelity you want the project timeline itself not imported XML.
    Noah
    FCPWORKS – FCPX Workflow
    FCP Exchange – FCPX Workshops
    XinTwo – FCPX Training
  • Declan Smith
    November 1, 2017 at 2:42 pm
    I have done a number of tests now and it does, as you suggest, seem to be linked to the XML export which appears not to export everything, rendering it only partially useful. I thought the whole point of the new fcpx xml format over the older FCS format was to include additional meta-data / fields & structure to be able to describe everything about the media and timelines, so maybe this is a bug, after all, the project, or timeline, is just a bunch of meta-data!
    This now appears to be related to a previous question I asked on the board regarding desktop / laptop workflow (https://forums.creativecow.net/thread/344/49061).
    I have posted a workflow that does appear to work for me, in that thread. Thankyou for your help.
    Declan Smith
